It is currently Mon Aug 11, 2025 4:45 pm
 Post subject: Hoof buffer
PostPosted: Sun Jul 03, 2016 5:39 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
This would work great for flattening sides before binding
http://www.stockhoffsonline.com/acatalog/Hoof-Buffer-Attachment-system.html#SID=8
Ed
These users thanked the author Ruby50 for the post: Patrick Nelson (Sun Jul 03, 2016 6:33 am)
 Post subject: Re: Hoof buffer
PostPosted: Sun Jul 03, 2016 6:47 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We use the larger version of this tool for working cutaways and some initial neck heel shaping- the larger is about 7-1/2" in length, but that smaller tool looks like it might be a little easier to control! There is also a smaller diameter version sold by Grizzly that pops up with the larger tool listing - also looks handy!
http://www.grizzly.com/products/7-1-2-x-2-1-4-Handheld-Pneumatic-Drum-Sander/D4595?utm_campaign=zPage
http://www.grizzly.com/products/4-x-1-1-8-Handheld-Pneumatic-Drum-Sander/D4594?utm_campaign=zPage
- Beth Brower
PostPosted: Sun Jul 03, 2016 7:58 am
Online
Glad to know someone makes these. Control that power!
PostPosted: Sun Jul 03, 2016 2:29 pm
City: Escondido
Zip/Postal Code: 92029
I have the Grizzly 7-1/2" sander and it is an indispensable tool. My only regret is the diameter is a smidgen too big to fit inside the cutaway. If they had a second one with a slightly smaller diameter I would add it to my tool set in a heart beat.
PostPosted: Sun Jul 03, 2016 9:29 pm
For those interested Industrial Abrasives has the same "hoof " sander for a few bucks less along with a good assortment of sleeves for the sander. I got it and really like it for the waist and cutaway sections where a scraper or flat block won't work.
http://www.industrialabrasives.com/2x412x7516-hand-held-sander-01346-p-128.html
Also this is slightly smaller (2" vs 2 1/4") than the larger grizzly sander so it might work for your cutaway.
PostPosted: Sun Jul 10, 2016 5:24 am
Last Name: O'Melia
City: Huntsville
State: Alabama
These are useful tools. I've got both of the grizzly models. Only complaint is the non-standard diameters meaning you must buy sleeves from Grizzly.
There is a downside to using these for side flattening. They can actually "round" the sides because they are pneumatic. Light application pressure only. Scrapers work best. But in a cutaway, not many options exist.
PostPosted: Sun Jul 10, 2016 5:54 am
First name: Willard
Last Name: Guthrie
City: Cumberland
These tools are cushioned contour sanders, so the air pressure in the bladder is adjustable and the sleeves made from more flexible material than standard oscillating spindle or drill press drum sleeves. We usually use this tool at close to the default 90 psi that the air distribution system in the shop provides for sanding cutaways and closer to 25-30 psi for other work, so worth setting the bladder pressure before each use for the task to be accomplished. At higher pressure , the drum is almost like a spindle sander's sleeve - the work stays flat and there is little or no give. At lower pressure, the sleeve has quite a bit of give, and allows compound contours curve contours to be worked, such as found in the heel area. Despite the availability of grits from extra coarse to very fine, we use the tool with fairly coarse sleeves for getting rid of the big divots or coarse shaping- a cork-on-CPVC-pipe sanding block with P150 and P220 is what we use for final leveling.
- Beth Brower
PostPosted: Sun Jul 10, 2016 8:41 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I've got a question for some of u experienced users. Please post an inflating valve that actually fits the narrow space. Those for inflating tires are a pain to use. Thanks!
PostPosted: Sun Jul 10, 2016 8:44 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
This work?
PostPosted: Mon Jul 11, 2016 5:22 am
This is from a while back a home brewed version
viewtopic.php?f=10117&t=25191&hilit=sander
Formerly JJH
PostPosted: Tue Jul 12, 2016 11:50 am
We use an inexpensive mountain bike air pump to inflate our bladder sanders -- we lock the handle in a vise so we can easily engage and disengage the pump from the sander.
Similar to this:
https://www.amazon.com/Petbly-Portable- ... APTG8X1Q2W
Ken Cierp
PostPosted: Tue Jul 12, 2016 12:57 pm
Last Name: Farmer
City: Durango
State: CO
For what it's worth, if you use a mountain bike pump like the one in the link you will probably be un able to get much past 60psi. They are not designed for high pressure. One designed for road bike tires or a floor pump will get you past100psi. One for air pressure in a mountain bike shock will take you to 250psi+ but will take a while.
PostPosted: Tue Jul 12, 2016 1:12 pm
David, since the maximum recommended pressure is 8 psi, for us that is not a concern.
http://cdn0.grizzly.com/manuals/d4595_m.pdf
Ken Cierp
PostPosted: Tue Jul 12, 2016 1:34 pm
Last Name: Farmer
City: Durango
State: CO
I hear you Ken.
I only mentioned it because Woodie G said he runs his at 90psi sometimes. He's either using a different rig or on the edge of some serious excitement.
PostPosted: Tue Jul 12, 2016 5:33 pm
I wouldn't put 90 psi in mine! Maybe Woodie knows something I don't idunno
PostPosted: Tue Jul 12, 2016 10:02 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Yeah, they're are not rated for high pressure. I was just looking for a simple way to inflate
PostPosted: Thu Jul 14, 2016 4:14 am
First name: Willard
Last Name: Guthrie
City: Cumberland
As the boss suggested, line pressure is 90 psi, but we have regulators at the drops we don't use all of it very often. What I should have said was that we inflate the tool until it is very rigid.
I can hear that - please stop snickering.
- Beth Brower
Users browsing this forum: bobgramann, Ken Lewis, Melt in the Sun, Mike Thomas, TripodBob and 54 guests
